跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement
你所需要的
  1. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Prepare your phone for disassembly: 步骤 1 中的图像 2,2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
    询问修复机器人
    添加评论
  2. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Heat the right edge: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
    询问修复机器人
    添加评论
  3. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    询问修复机器人
    添加评论
  4. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the right adhesive: 步骤 4 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the right adhesive: 步骤 4 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the right adhesive: 步骤 4 中的图像 3,3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  5. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Heat the bottom edge: 步骤 5 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
    询问修复机器人
    添加评论
  6. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the corner adhesive: 步骤 6 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the corner adhesive: 步骤 6 中的图像 2,2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
    询问修复机器人
    添加评论
  7. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: 步骤 7 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: 步骤 7 中的图像 2,2
    • Insert a second pick at the bottom right corner.
    • Slide the opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  8. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Heat the left edge: 步骤 8 中的图像 1,1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
    询问修复机器人
    添加评论
  9. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the corner adhesive: 步骤 9 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the corner adhesive: 步骤 9 中的图像 2,2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
    询问修复机器人
    添加评论
  10. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the left adhesive: 步骤 10 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the left adhesive: 步骤 10 中的图像 2,2
    • Insert a third opening pick at the bottom left corner.
    • Slide the pick toward the top left corner to separate the adhesive.
    • Leave the pick near the top left corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  11. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Heat the top edge: 步骤 11 中的图像 1,1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
    询问修复机器人
    添加评论
  12. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the corner adhesive: 步骤 12 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the corner adhesive: 步骤 12 中的图像 2,2
    • Rotate the opening pick around the top left corner to separate the adhesive.
    询问修复机器人
    添加评论
  13. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the top adhesive: 步骤 13 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the top adhesive: 步骤 13 中的图像 2,2
    • Insert a fourth opening pick at the top left corner.
    • Slide the pick toward the top right corner to separate the adhesive.
    • Leave the pick near the top right corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  14. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the rear mic adhesive: 步骤 14 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Separate the rear mic adhesive: 步骤 14 中的图像 2,2
    • There's a square of adhesive around the rear microphone, just above the flash.
    • Line up the tip of an opening pick with the flash.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
    询问修复机器人
    添加评论
  15. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the back cover: 步骤 15 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the back cover: 步骤 15 中的图像 2,2
    • Grab and remove the back cover.
    • If the back cover is not lifting easily, use an opening pick to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive, but your device will lose its IP (Ingress Protection) rating.
    • Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    询问修复机器人
    添加评论
  16. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: 步骤 16 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: 步骤 16 中的图像 2,2
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    询问修复机器人
    添加评论
  17. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: 步骤 17 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: 步骤 17 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: 步骤 17 中的图像 3,3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
    询问修复机器人
    添加评论
  18. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker: 步骤 18 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker: 步骤 18 中的图像 2,2
    • Insert the point of a spudger in the notch at the top left corner of the loudspeaker, which is marked by an arrow.
    • Pry up to unclip the loudspeaker from the frame.
    询问修复机器人
    添加评论
  19. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement: 步骤 19 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement: 步骤 19 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement: 步骤 19 中的图像 3,3
    • Use your fingers to lift the loudspeaker away from the frame.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
    询问修复机器人
    添加评论
  20. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the battery: 步骤 20 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the battery: 步骤 20 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery press connector.
    询问修复机器人
    添加评论
  21. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: 步骤 21 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: 步骤 21 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: 步骤 21 中的图像 3,3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
    询问修复机器人
    添加评论
  22. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement: 步骤 22 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement: 步骤 22 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement: 步骤 22 中的图像 3,3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
    询问修复机器人
    添加评论
  23. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the interconnect cables: 步骤 23 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the interconnect cables: 步骤 23 中的图像 2,2
    • Grab and remove the interconnect cables from the phone.
    询问修复机器人
    添加评论
  24. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the SIM card tray: 步骤 24 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the SIM card tray: 步骤 24 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the SIM card tray: 步骤 24 中的图像 3,3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
    询问修复机器人
    添加评论
  25. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard screws: 步骤 25 中的图像 1,2 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard screws: 步骤 25 中的图像 2,2
    • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the daughterboard.
    询问修复机器人
    添加评论
  26. Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard: 步骤 26 中的图像 1,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard: 步骤 26 中的图像 2,3 Samsung Galaxy S24 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard: 步骤 26 中的图像 3,3
    • Use the point of a spudger to pry up the top right corner of the daughterboard.
    • Don't pry against the battery. Angle your spudger so you pry against the frame.
    • Remove the daughterboard.
    • During reassembly, reinsert the USB-C port into its recess at an angle before pressing the daughterboard flat onto the frame.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Spencer Pennington
于09/09/23注册
25,970 声望
创作了127篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了17,860篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 71
过去 30 天: 301
总计 3,479
