跳转到主内容
Samsung Galaxy S Vibrant Camera Lens Replacement
你所需要的
  1. Samsung Galaxy S Vibrant Camera Lens Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy S Vibrant Camera Lens Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy S Vibrant Camera Lens Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Camera Lens Replacement, Midframe: 步骤 3 中的图像 1,1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 4 中的图像 1,1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 5 中的图像 3,3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy S Vibrant Camera Lens Replacement: 步骤 6 中的图像 2,2
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Camera Lens Replacement, Camera Lens: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the ribbon cable and camera lens by tugging gently at the base of the ribbon cable either by pinching with fingers or with the Tweezers.
    • Only use the pinching method when the camera lens is already broken so as to avoid damage.
结论
团队
Cal Poly, Team 18-37, Regan Winter 2013 Cal Poly, Team 18-37, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G37
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,479
