跳转到主内容
Samsung Galaxy S Vibrant Battery Replacement
你所需要的
  1. Samsung Galaxy S Vibrant Battery Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy S Vibrant Battery Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy S Vibrant Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy S Vibrant Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
结论
团队
Cal Poly, Team 18-37, Regan Winter 2013 Cal Poly, Team 18-37, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G37
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,601
