这个拆解是不是 维修指南。 要维修你的的Samsung Galaxy S,请使用我们的维修手册 。
The battery!
It shows 1500mAh, decent.
also the manufacturing date is shown.
I added a piece of sticky tack, to cover up the IMEI code, again showing how hi-tec i am!
This is the point of no return when it comes to warranty.
But that's okay, i'm using this phone for spares anyways.
Sticky tack
Screws, 7 to be exact!
Here comes the first tricky part. it's easiest to start right under the volume button, and work your way from there.
Be extremely careful if you are using metal tools like i am. it will easily damage components if you accidentally jam it in.
And it's off!
Lets see the innards of this thing.
The back camera.
And the front facing camera
The speaker, actually quite large.
Water detector on the plastic cover, as you can see, this is a water damaged phone. normally you would see a purple pattern.
Contacts, probably for antennas.
Now detach the power button, its held down by a little bit of glue, not a big deal.
Lift it carefully, making sure no connectors are stuck on. Especially the one marked red.
Now for the component that holds the headphone jack, earpiece and both proximity and light sensor.
There is a cool app "androsensor" that lets you access all the sensors in your phone!
This thing quite literally just pulls off. you can remove it without any special tools!
Be careful not to tug on the cables too hard! there is some glue, but it peels right off.
Now for the bottom portion, including the Mic, vibrating engine and the antenna board.
I couldn't get it off completely, but i can give you a good picture of what it looks, lets see..
We seem to be connected together!
see that? the AMOLED display is actually transparent!
Can't go farther than this without a heat gun that I don't have. I tried removing the bezel, but with no luck.
That's about it! Thank you for reading, and please give me feedback!
This is my first teardown, and pictures were taken with a functional Galaxy s phone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
