简介
Use this guide to replace the front panel assembly, including the digitizer, speaker, and OK button on the Samsung Galaxy S Plus (i9001)
  1. Unscrew 7 screws on the rear using a Phillips screw driver. Unscrew 7 screws on the rear using a Phillips screw driver.
    • Unscrew 7 screws on the rear using a Phillips screw driver.
  2. Unhook the rear using a soft plastic prying tool to remove the rear cover Be careful not to damage the rear cover when unhooking it. Be careful not to damage the rear cover when unhooking it.
    • Unhook the rear using a soft plastic prying tool to remove the rear cover
    • Be careful not to damage the rear cover when unhooking it.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
    • Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
  5. Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
    • Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
    • Disconnecting the camera connector isn't necessary!
  6. After disconnecting the connectors carefully pull the Main PBA out of the bracket.
    • After disconnecting the connectors carefully pull the Main PBA out of the bracket.
    • Make sure that the Power Key FPCB does not get stuck!
  7. Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame Pull out the Receiver module from the bracket. Be careful not to damage the FPC. Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
    • Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame
    • Pull out the Receiver module from the bracket. Be careful not to damage the FPC.
    • Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
结论
13等其他人完成本指南。
Joao de Matos
于2013年07月02日注册
362 信誉积分
撰写一个指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 12
总计 7,794
