当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
这一步没有撬棒也可以完成。
将撬棒进入电池与手机之间的小缺口。
将电池从凹槽中取出。
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
For reassembly, push the SIM card into the slot until it clicks in place.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
For reassembly, push the microSD card into the slot until it clicks in place.
Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
The midframe lightly snaps in place, and can be removed with very little force.
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
