跳转到主内容
简介
Use this guide to replace the battery.
If your battery is swollen, take appropriate precautions.
  1. Samsung Galaxy S III Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S III Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 3 中的图像 2,2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 4 中的图像 2,2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Battery Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 5 中的图像 2,2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
    very easy to follow instructions clear and concise
    Deric JONES - 回复
  6. Samsung Galaxy S III Battery Replacement, Battery: 步骤 6 中的图像 1,2 Samsung Galaxy S III Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Battery Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy S III Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the battery.
结论
90等其他人完成本指南。
2条评论
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - 回复
Super simple. Thanks!
bmwherry - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 17
过去的30天: 94
总计 63,125
