简介
Use this guide to replace the battery.
If your battery is swollen, take appropriate precautions.
你所需要的
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
90等其他人完成本指南。
3条评论
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - 回复
