跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Samsung Galaxy S II,应参考我们的维修指南
  1. Samsung Galaxy S II Teardown, Remove back of phone: 步骤 1 中的图像 1,3 Samsung Galaxy S II Teardown, Remove back of phone: 步骤 1 中的图像 2,3 Samsung Galaxy S II Teardown, Remove back of phone: 步骤 1 中的图像 3,3
    • Find the small divot and use a plastic tool or your fingernail to remove the plastic cover off the back. This step requires no removal of screws.
  2. Samsung Galaxy S II Teardown: 步骤 2 中的图像 1,2 Samsung Galaxy S II Teardown: 步骤 2 中的图像 2,2
    • Remove the 11 screws from the back of the phone. This will require a Philips #00 screwdriver.
  3. Samsung Galaxy S II Teardown: 步骤 3 中的图像 1,2 Samsung Galaxy S II Teardown: 步骤 3 中的图像 2,2
    • Separate the screen and internals from the casing on the back by using a small plastic tool or your fingernail to get under the screen and lift it up. Once it has been unclipped, pull the 2 completely apart.
  4. Samsung Galaxy S II Teardown: 步骤 4 中的图像 1,1
    • The back of the screen should look like this. From here, we have access to any fixes that would nee to be made for the phone.
Devon Crump
于11/08/16注册
284 声望
撰写一个指南
1指南评论
Is this device Galaxy S2 or Galaxy Note2? It seem to be Note2…
jehongjeon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 999
