跳转到主内容
Samsung Galaxy S II T989 Speaker Replacement
你所需要的
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 步骤 1 中的图像 1,3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 步骤 1 中的图像 2,3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 步骤 2 中的图像 1,3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 步骤 2 中的图像 2,3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. Samsung Galaxy S II T989 Speaker Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy S II T989 Speaker Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy S II T989 Speaker Replacement: 步骤 3 中的图像 3,3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
结论
2等其他人完成本指南。
Joshua King
于03/26/14注册
1,378 声望
创作了9篇指南
团队
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G5
4 名成员
创作了9篇指南
3条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 1,524
