简介
The media card stores pictures, videos, music, sounds, and downloads. While this card is not vital to the operation of the phone it is still a useful addition to the phone.
工具
无需工具。
配件
无需配件。
  1. To remove the rear cover, locate the tab indicated by the red outline. Using your fingernail, gently pry the rear cover. Using your fingernail, gently pry the rear cover.
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. The media card is found inside the area indicated with the red rectangle.  The card itself is small and black making it hard to easily see. After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal. After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
结论
另外一个人完成了本指南。
Joshua King
于2014年03月26日注册
1,330 信誉积分
创作了9篇指南
团队
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G5
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 364
