简介
A faulty or damaged battery can cause a variety of problems ranging from the phone not turning on to a possible destruction of the phone. When replacing the battery it is important to make sure the phone is turned off to prevent any possible loss of data.
If your battery is swollen, take appropriate precautions.
你所需要的
To remove the rear cover, locate the tab indicated by the red outline.
Using your fingernail, gently pry the rear cover.
The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
After the battery starts to lift upwards, use your hand to hold and remove it.
4等其他人完成本指南。
