跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S II Front Glass/Digitizer Replacement
你所需要的
视频概述
  1. Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: 步骤 1 中的图像 1,2 Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: 步骤 1 中的图像 2,2
    • We have a Samsung Galaxy S II with broken screen.
  2. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 2 中的图像 3,3
    • Remove your battery, the SIM card and the SD card.
    • Remove the 7 screws highlighted in red.
  3. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 3 中的图像 3,3
    • Use a plastic tool to remove the rear housing.
  4. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 4 中的图像 2,2
    • The mother board is held by 2x screws. Remove them.
  5. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 5 中的图像 3,3
    • Remove the cables that are highlighted in red, before continuing to the screen.
  6. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 6 中的图像 3,3
    • Release the side buttons. The arrow will point you to where they are.
  7. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 7 中的图像 2,2
    • Careful release the motherboard from it's housing.
  8. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 8 中的图像 2,2
    • At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
    • We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
    • Use a hot air to soften the adhesive enough to remove the glass.
  9. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 9 中的图像 3,3
    • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
  10. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 10 中的图像 3,3
    • Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
  11. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 11 中的图像 3,3
    • Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
  12. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 12 中的图像 3,3
    • Clean the frame from the remains of tape.
  13. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 13 中的图像 3,3
    • Test the new spare part before reassembling.
  14. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 14 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 14 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 14 中的图像 3,3
    • Install the LCD&Digitiser on it's housing.
    • Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
  15. Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 15 中的图像 1,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 15 中的图像 2,3 Samsung Galaxy S II Front Glass/Digitizer Replacement: 步骤 15 中的图像 3,3
    • To reassemble your device, follow these instructions in reverse order.
结论
32等其他人完成本指南。
ZFix
于12/09/13注册
196,793 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
333 名成员
创作了1,479篇指南
9指南评论
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - 回复 分享
Yes, removing the glass is very difficult and you must have some experience from before.
ZFix - 回复 分享
To moderators: please un-archive this guide: there's no replacement or "updated version of the guide" among the current guides.
yurkennis - 回复 分享
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
Frederic Morelli - 回复 分享
how much the cost in replacement display with fame.....samsung galaxy s2
Bhola Shrestha - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 46
总计 99,675
