跳转到主内容
简介
This guide will show how to properly replace the SD card slot cover on a Samsung Galaxy S Blaze 4G. The replacement of the SD card slot cover is an easy process with no surprises. You will need to be careful while taking out the screws, the screws will damage easily.
  1. Remove the back plate to reveal the battery.
    • Remove the back plate to reveal the battery.
  2. Remove the battery from the device.
    • Remove the battery from the device.
  3. Apple Watch 套装
    Screen and battery repairs just got easier.
    现在开始购物
    Apple Watch 套装
    现在开始购物
  4. Use a Phillips head screwdriver size 00. Remove the 4mm screws from the frame.
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  5. Use the blue plastic opening tool to pry the frame off the phone.
    • Use the blue plastic opening tool to pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  6. The SD cover is held in place on the frame by a small tab. Unhook the tab of the SD card slot cover from the frame of the device.
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
结论
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3等其他人完成本指南。
Rene Bolanos
于2015年03月05日注册
435 信誉积分
创作了2篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 160
