跳转到主内容
Samsung Galaxy S Blaze Power Button Replacement
你所需要的
  1. Samsung Galaxy S Blaze Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Samsung Galaxy S Blaze Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Samsung Galaxy S Blaze Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Samsung Galaxy S Blaze Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Samsung Galaxy S Blaze Power Button Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S Blaze Power Button Replacement: 步骤 3 中的图像 2,2
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  4. Samsung Galaxy S Blaze Power Button Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy S Blaze Power Button Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy S Blaze Power Button Replacement: 步骤 4 中的图像 3,3
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
结论
Dustin
于03/12/14注册
1,213 声望
创作了6篇指南
一条评论
Please can someone help me with samsung t769 power way on the board ?
Nyawu Ebenezer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,199
