跳转到主内容
Samsung Galaxy S Blaze Motherboard Replacement
你所需要的
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S Blaze Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy S Blaze Motherboard Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy S Blaze Motherboard Replacement: 步骤 5 中的图像 3,3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: 步骤 6 中的图像 1,1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
结论
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3等其他人完成本指南。
Rene Bolanos
于03/05/15注册
435 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 823
