跳转到主内容
简介
The frame replacement is the next major component that will be required to be removed.
  1. Use a Phillips head screwdriver size 00. Remove the 4mm screws from the frame. The screws can be removed in any order.
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  2. Use the blue plastic opening tool to remove the frame from the device. Work around the device with the opening tool until the frame is completely off the device. You may need to use some force to pry the frame off of the device.
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
结论
另外一个人完成了本指南。
Daniell Gianelloni
于2015年03月05日注册
389 信誉积分
创作了3篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 175
