跳转到主内容
Samsung Galaxy S Blaze Display Replacement
你所需要的
  1. Samsung Galaxy S Blaze Display Replacement, Display: 步骤 1 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement, Display: 步骤 1 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement, Display: 步骤 1 中的图像 3,3
    • Remove the battery cover,
    • the battery and the SIM card if your phone has one.
  2. Samsung Galaxy S Blaze Display Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement: 步骤 2 中的图像 3,3
    • Remove the eight Phillips head screws
    • All eight screws are 4mm and are identical. No reason to keep them separated.
    • Use a plastic opening tool to separate the frame from the phone
  3. Samsung Galaxy S Blaze Display Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement: 步骤 3 中的图像 3,3
    • Continue to work all the way around the frame.
    • Different size of the plastic opening tools can be used
    • Separate the frame
  4. Samsung Galaxy S Blaze Display Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement: 步骤 4 中的图像 3,3
    • Disconnect the front camera flex
    • Disconnect the audio jack flex
    • Disconnect the control button flex
  5. Samsung Galaxy S Blaze Display Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement: 步骤 5 中的图像 3,3
    • Gently lift the logic board above the frame,
    • and flip it to its side. Remove the LCD flex
    • The logic board can now be safely removed.
  6. Samsung Galaxy S Blaze Display Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement: 步骤 6 中的图像 3,3
    • The front display is adhered to the frame. It will be necessary to use a heatgun (on very low) or a good hairdryer to loosen the glue.
    • Apply the heat on the outside of the display. Do not stay to long in one are, move the heat continously around the outside of the display.
    • With the glue soft enough, use a small spatula, screwdriver or other small tool to separate the display from the frame.
    • The LCD may separate from the digitizer and remain affixed to the frame. This will cause a sparkly mess.
  7. Samsung Galaxy S Blaze Display Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy S Blaze Display Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy S Blaze Display Replacement: 步骤 7 中的图像 3,3
    • LCD is now removed from the frame.
    • The PCB for the buttons is glued to the bottom of the LCD. Remove it slowly and carefully. An opening tool will make it easier.
    • There will be enough adhesive on the button PCB to adhere it to the new LCD.
结论
To reassemble your device, follow these instructions in reverse order. The frame should have enough adhesive to provide a secure grip. If additional glue should be necessary, preference should be given to rubber cement. This will ensure that, should another display replacement be necessary, the glue will come off with heat again.
3等其他人完成本指南。
oldturkey03
于09/29/10注册
778,255 声望
创作了118篇指南
团队
Global Fixers Global Fixers 的会员
Community
31 名成员
创作了520篇指南
一条评论
Can just the glass be removed on this device like the Galaxy S3 Meaning is the digitizer attatched to the glass or is it like the S3 where the digitizer is not attatched to the glass?
Andrew Knight - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 6,654
