跳转到主内容
Samsung Galaxy R Motherboard Replacement
你所需要的
  1. Samsung Galaxy R Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy R Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy R Motherboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Motherboard Replacement, Battery: 步骤 2 中的图像 1,3 Samsung Galaxy R Motherboard Replacement, Battery: 步骤 2 中的图像 2,3 Samsung Galaxy R Motherboard Replacement, Battery: 步骤 2 中的图像 3,3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Motherboard Replacement, Screws: 步骤 3 中的图像 1,2 Samsung Galaxy R Motherboard Replacement, Screws: 步骤 3 中的图像 2,2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Motherboard Replacement, Bottom Panel: 步骤 4 中的图像 1,3 Samsung Galaxy R Motherboard Replacement, Bottom Panel: 步骤 4 中的图像 2,3 Samsung Galaxy R Motherboard Replacement, Bottom Panel: 步骤 4 中的图像 3,3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Motherboard Replacement, Top Panel: 步骤 5 中的图像 1,3 Samsung Galaxy R Motherboard Replacement, Top Panel: 步骤 5 中的图像 2,3 Samsung Galaxy R Motherboard Replacement, Top Panel: 步骤 5 中的图像 3,3
    • Use tweezers to grasp the circular silver metal piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Motherboard Replacement, Remove Motherboard: 步骤 6 中的图像 1,1
    • If you want to replace motherboard, gently pull motherboard from the back of the phone.
    • The parts indicated in red color are attached by adhesive to the back of the phone, so more force will be necessary to remove these areas.
结论
3等其他人完成本指南。
Keon Horahan
于10/13/14注册
841 声望
创作了6篇指南
团队
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G3
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,758
