跳转到主内容
Samsung Galaxy R Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy R Headphone Jack Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy R Headphone Jack Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy R Headphone Jack Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Headphone Jack Replacement, Battery: 步骤 2 中的图像 1,3 Samsung Galaxy R Headphone Jack Replacement, Battery: 步骤 2 中的图像 2,3 Samsung Galaxy R Headphone Jack Replacement, Battery: 步骤 2 中的图像 3,3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Headphone Jack Replacement, Screws: 步骤 3 中的图像 1,2 Samsung Galaxy R Headphone Jack Replacement, Screws: 步骤 3 中的图像 2,2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 1,3 Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 2,3 Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 3,3
    • The headphone jack is located near the top left side of the motherboard.
    • To remove the headphone jack, gently pull on the area indicated in red until it detaches from the motherboard.
结论
4等其他人完成本指南。
Keon Horahan
于10/13/14注册
841 声望
创作了6篇指南
团队
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G3
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,397
