跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Prime Front Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Prime Front Facing Camera  Replacement, Removing back cover: 步骤 1 中的图像 1,1
    • Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Lift on the tab to pry the back cover off of the phone.
    • Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
  2. Samsung Galaxy Prime Front Facing Camera  Replacement, Remove The Battery: 步骤 2 中的图像 1,1
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Prime Front Facing Camera  Replacement, Remove The SD And LCD Ribbon Cable: 步骤 3 中的图像 1,2 Samsung Galaxy Prime Front Facing Camera  Replacement, Remove The SD And LCD Ribbon Cable: 步骤 3 中的图像 2,2
    • To remove the SD card and Sim card, look above the battery bay and slide the card out.
    • Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
  4. Samsung Galaxy Prime Front Facing Camera  Replacement, Removing screws: 步骤 4 中的图像 1,1
    • Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
    • Keep the screws on a magnetic mat or in a secure location.
  5. Samsung Galaxy Prime Front Facing Camera  Replacement, Seperating Bezel and Screen: 步骤 5 中的图像 1,2 Samsung Galaxy Prime Front Facing Camera  Replacement, Seperating Bezel and Screen: 步骤 5 中的图像 2,2
    • Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
    • Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
    • You can also push the screen out in the empty slot where the battery was to separate.
    • It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
  6. Samsung Galaxy Prime Front Facing Camera  Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Prime Front Facing Camera  Replacement: 步骤 6 中的图像 2,2
    • Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
    • Lift from the top of the loudspeaker unit to release from the phone.
    • You do not need to remove the motherboard to do this.
  7. Samsung Galaxy Prime Front Facing Camera  Replacement, Front Facing Camera: 步骤 7 中的图像 1,1
    • Use a plastic spudger to disconnect the ribbon cable from the motherboard.
    • The camera will be free to remove.
结论
另外一个人完成了本指南。
Alex Boyle
于07/31/18注册
374 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G1, Liner Summer 2018 UW Tacoma, Team S1-G1, Liner Summer 2018 的会员
UWT-LINER-SU18S1G1
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 33
总计 1,431
