跳转到主内容
Samsung Galaxy Prevail Touch Screen Replacement
你所需要的
  1. Samsung Galaxy Prevail Touch Screen Replacement, Touch Screen: 步骤 1 中的图像 1,1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Touch Screen Replacement: 步骤 2 中的图像 1,1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Touch Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Touch Screen Replacement: 步骤 4 中的图像 1,1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Touch Screen Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
  6. Samsung Galaxy Prevail Touch Screen Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
    • The shield plate will not be fully removed, it is attached to the front panel with a ribbon cable.
  7. Samsung Galaxy Prevail Touch Screen Replacement: 步骤 7 中的图像 1,1
    • Using the spudger lift up the LCD screen and replace with the new screen.
结论
另外一个人完成了本指南。
Ricardo Zuloaga
于09/15/16注册
525 声望
创作了5篇指南
团队
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 735
