跳转到主内容
Samsung Galaxy Prevail Rear Speaker Replacement
你所需要的
  1. Samsung Galaxy Prevail Rear Speaker Replacement, Rear Speaker: 步骤 1 中的图像 1,1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Speaker Replacement: 步骤 2 中的图像 1,1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Speaker Replacement: 步骤 4 中的图像 1,1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The motherboard will now be accessible.
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Prevail Rear Speaker Replacement: 步骤 5 中的图像 2,2
    • Using the spudger, carefully lift upward to remove the speaker assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
结论
Ricardo Zuloaga
于09/15/16注册
525 声望
创作了5篇指南
团队
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 210
