跳转到主内容
Samsung Galaxy Prevail Rear Camera Lens Replacement
你所需要的
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: 步骤 1 中的图像 1,1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: 步骤 4 中的图像 1,1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: 步骤 5 中的图像 1,1
    • Replace the secondary rear panel which has the camera lens attached.
结论
Ricardo Zuloaga
于09/15/16注册
525 声望
创作了5篇指南
团队
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 9
总计 273
