跳转到主内容
Samsung Galaxy Prevail Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy Prevail Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Using the nylon spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Using the spudger lift the speaker assembly upward, so you may have access to the headphone assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
  6. Samsung Galaxy Prevail Headphone Jack Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Prevail Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Using the spudger, carefully unplug and remove the headphone port assembly by lifting upward on the ribbon cable.
    • The headphone jack should lift off of the motherboard.
结论
另外一个人完成了本指南。
Ricardo Zuloaga
于09/15/16注册
525 声望
创作了5篇指南
团队
USF Tampa, Team 17-6, Blackwell Fall 2016 USF Tampa, Team 17-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 9
总计 309
