简介
This guide will teach you how to replace the vibration motor of the Samsung Galaxy Prevail 2. Prior knowledge of how to use a soldering iron is required.
你所需要的
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
Use your thumbs to separate the motherboard from the back of the phone.
With the plastic prying tool, lift up the flap in order to fully open the motherboard.
With the soldering iron remove the solder attaching the vibration motor to the motherboard.
5等其他人完成本指南。
