跳转到主内容
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: 步骤 1 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: 步骤 1 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: 步骤 1 中的图像 3,3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: 步骤 2 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: 步骤 2 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: 步骤 3 中的图像 1,2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: 步骤 3 中的图像 2,2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: 步骤 4 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: 步骤 4 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: 步骤 4 中的图像 3,3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: 步骤 5 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: 步骤 5 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: 步骤 5 中的图像 3,3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: 步骤 6 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: 步骤 6 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: 步骤 6 中的图像 3,3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: 步骤 7 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: 步骤 7 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: 步骤 7 中的图像 3,3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: 步骤 8 中的图像 1,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: 步骤 8 中的图像 2,3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: 步骤 8 中的图像 3,3
    • Carefully lift and remove the camera from its position.
结论
8等其他人完成本指南。
团队
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,427
