跳转到主内容
Samsung Galaxy Prevail 2 Battery Replacement
你所需要的
  1. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: 步骤 1 中的图像 1,3 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: 步骤 1 中的图像 2,3 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: 步骤 1 中的图像 3,3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: 步骤 2 中的图像 1,3 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: 步骤 2 中的图像 2,3 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Gently pull the battery out of the phone.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 14-4, Leahy Fall 2014 USF Tampa, Team 14-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G4
4 名成员
创作了5篇指南
3条评论
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
lindabuhl5729 - 回复
Mine doing the same
Chuck Slagel - 回复
"To reassemble your device, follow these instructions in reverse order" seriously?! I mean even an idiot should know that!
illy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,903
