简介
How to disassemble the phone and change broken Digitizer / Glass or LCD Display.
________________________Vedeo manual:________________________
你所需要的
视频概述
Remove any SIM and SD card.
Remove 7x Phillips screws.
Use a plastic tool to disassemble the rear housing.
Disconnect the LCD Display flex cable.
Lift up the board and disconnect the Touchscreen flex cable.
Now you can remove the Motherboard.
Warm the touchscreen to make separating the LCD Display more easy
In the four corners of LCD display there are small metal plates. Use one of them to lift a little the LCD and put the plastic tool.
Be careful not to break the display.
3等其他人完成本指南。
