跳转到主内容
Samsung Galaxy Player 4.2 Battery Casing Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your finger to press in the battery cover tab on the upper right hand corner of the back of the device.
    • Pry the battery cover off the device by pressing in and lifting up.
    • When reassembling, align the top portion of the back cover to the top of the device and press down until it clicks into place.
  2. Samsung Galaxy Player 4.2 Battery Casing Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Player 4.2 Battery Casing Replacement: 步骤 2 中的图像 2,2
    • Press your finger into the groove on the bottom left hand side of the battery.
    • Pry the battery out by lifting your finger up.
  3. Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery Casing: 步骤 3 中的图像 1,2 Samsung Galaxy Player 4.2 Battery Casing Replacement, Battery Casing: 步骤 3 中的图像 2,2
    • Remove the six 2.0mm Phillips #0 screws from the battery casing.
  4. Samsung Galaxy Player 4.2 Battery Casing Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Player 4.2 Battery Casing Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Player 4.2 Battery Casing Replacement: 步骤 4 中的图像 3,3
    • Starting at the top, insert the plastic opening tool at the seam between the battery casing and the main body of the device.
    • Pry up, working around the seam from top to bottom.
    • The battery casing fits snuggly against the main body of the device. You may need to apply some moderate force to free it.
    • The volume button may pop out when you free the battery casing.
结论
5等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,017 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,137篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 433
