简介
This guide demonstrates the replacement of the motherboard in a Samsung Galaxy On5.
Make sure you check if the problems you are experiencing could be related to any other part of the phone, such as the LCD Screen or faulty wiring. Once you are certain the issue is a broken motherboard, use this guide to aid you in replacing it.
你所需要的
Use a plastic pry tool to lift the front-facing camera from its housing.
Using a Phillips #00 screwdriver, remove the screw securing the rear-facing camera.
8等其他人完成本指南。
