简介
Follow this guide to replace the charging assembly on your Samsung Galaxy Note9.
你所需要的
Insert a SIM card eject tool straight into the hole in the SIM card tray.
Press to eject the SIM card tray.
Power off your phone before beginning disassembly.
Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
Apply a suction handle to the back cover.
Lift with a suction handle to create a gap between the back cover and the frame of the phone.
Insert an opening pick into the gap.
Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
Starting from the center, cut the adhesive up and down the right side with an opening pick.
Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
Turn on your phone and test your repair before installing new adhesive and resealing the phone.
Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
步骤 14 Remove the upper midframe
注意:步骤 14-17 源自标记为进行中的 指南。
Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
Use tweezers to remove the front camera.
Use the tip of a spudger to disconnect the iris scanner from the motherboard.
Use tweezers to remove the iris scanner.
Use the flat end of a spudger to pry the front sensor connector out of its socket.
Use the flat end of a spudger to disconnect the display cable from the motherboard.
Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
Remove the two 3.2 mm Phillips screws from the charging assembly.
19等其他人完成本指南。
6条评论
How do I put the back back on?
Hey William, thanks for the question! Check out the second bullet on step 13: To install a back cover:
Excellent guide.
After reassembling to step 17( reconnecting the battery) I tried powering on the phone. Nothing happened. I connected to a charger,, the phone vibrated and the red blinking light appeared. I left the phone connected to the charger for an hour, tried to power on and nothing happened. I checked to make sure all the connections were tight, but to no avail. I tried a soft reset, but that didn’t work either. Any idea what I did wrong?
Thank you!
Since there are signs of life when you turn on/charge the phone, but nothing on screen, here’s what I would try:
1. Disconnect the charger
2. Disconnect the battery cable from the motherboard
3. Disconnect the display cable from the motherboard
4. Reconnect the display cable
5. Reconnect the battery cable
6. Power on to test
If that does not fix it, another cable may not be properly connected. This sometimes prevents certain phones from powering on. Otherwise the display connector may have been damaged during the repair.
