跳转到主内容
Samsung Galaxy Note8 Touchscreen and LCD Replacement
    • Insert a comment here
终点
26等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
ian mdx
于06/30/16注册
9,266 声望
创作了17篇指南
10指南评论
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - 回复
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - 回复
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - 回复
Will the phone remain waterproof after this repair?
cj-dm - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 97
总计 25,585
