简介
使用本指南更换 Samsung Galaxy Note 8 中损坏的NFC天线和充电线圈组件。
在拆卸手机之前,请将电池放电至25%以下。如果意外被刺破,电池会着火和/或爆炸,但如果放电,发生这种情况的可能性要低得多。
如果你的电池膨胀,请不要加热手机。如果需要,你可以使用滴管或注射器在后盖边缘周围注入异丙醇(90 +%)以削弱粘合剂。膨胀后的电池可能非常危险,因此请小心佩戴护目镜并保持谨慎操作,或者如果你不确定如何继续操作,请将其送到专业人士手中。
打开三星 Galaxy Note 8 将“损坏设备上的防水密封。如果你不更换粘合剂密封件,你的手机将“正常运行”,但是防水功能'将失去。
本指南涉及拆除后玻璃盖,你需要更换粘合剂才能将后盖重新连接到手机上。
你所需要的
用一个吸盘来拉开后盖并将一个三角撬片插到后盖和边框的缝隙里。
一边拉着吸盘,一边用翘片从侧边中间开始沿着边缘滑动来切开密封胶
向手机的底部移动撬片,并把它留在那里(像图2一样)(你肯定不想你刚刚切开的密封胶又双叒叕粘到一起了)
插进另一个翘片,并把它移到手机的顶部(像图3一样)
I used an X-acto knife with the flat blade to get it started. I tried using the suction cup - but it’s difficult to get good leverage. Once I got the cover started - I used the metal pry tool (sharpened with a dremel file) and a business card to work it open.
This is definitely the hardest part.
Once off I see all the glue on the curved part of the chassis NOTON THE BACK. Apply heat to curved edges.
Lyle Walsh - 回复
当三条边的胶水都被划开了以后,你就可以缓慢地打开背面玻璃了。
当你翻开背面玻璃时,当心指纹识别器的连接线。你可能需要把链接线分开,下一步有所说明。
I broke the back camera cover for the NUT 8 and then I bought a commercial cover and installed it but the quality of the picture became very bad and my question is, do you know where to get the original cover at a reasonable price?
用一副镊子来取下指纹识别器的接口。
don't skip disconnecting the sensor, even if isn't still glued to the case. it has to move away from the NFC/charging coil assembly in order to free the latter so it can be lifted away from the battery.
取下后盖玻璃。
How do you swap the fingerprint sensor
Lukus Carr - 回复
You can use a tweezer to swap the fingerprint sensor, you might be careful when doing the step 6, additionally, a tweezer will be helpful when reassemble the fingerprint sensor. please note that your new back cover needs to have the fingerprint adhesive on. most of the product did not have. i have get a LUVSS brand from amazon which came with all OEM adhesive and full set tools, even a B6000 glue, best option to go for replacing the note 8 back glass
使用顶部边缘的撬片,以便在NFC天线和充电线圈组件与外壳之间进行操作。
撬出外壳顶部的组件。
请按逆序操作重组设备。如有必要请重新涂抹粘合剂。
8等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
I used a heat gun to soften the glue - worked it around the edges, moving the heat gun quickly. As this is my first attempt, I’m still calibrating on this - but other guides mention getting the back cover hot enough so as it’s just too hot to touch. I also have a temp probe on my multi-meter, and I measured appx. 75 deg. C.
One of the other guides showed using a electronics hot plate set to 105 deg C for 60 sec.
Phil Brooks - 回复
