简介
The Samsung Galaxy Note 7 is a rather dangerous phone, but even if it's rare and borderline unusable, it still needs proper documentation and maintenance.
NOTE: This guide assumes that you have a replacement screen + midframe with the other non-motherboard parts (speakers, S-pen compartment, etc).
你所需要的
Apply heat to the back panel, use a guitar pick and suction cup to carefully remove the adhesive and remove the back panel.
Using the flat end of a plastic spudger, carefully remove and lift up every connector on the board.
Make sure to press them a little further upward using the spudger, or else they might end up blocking the motherboard from being lifted up, and can also get stuck underneath it during the reassembly process.
另外一个人完成了本指南。
