跳转到主内容
Samsung Galaxy Note5 Volume Button Replacement
你所需要的
  1. Samsung Galaxy Note5 Volume Button Replacement, SIM Card Tray: 步骤 1 中的图像 1,1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Volume Button Replacement: 步骤 2 中的图像 1,1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Volume Button Replacement, Power Button: 步骤 3 中的图像 1,1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Volume Button Replacement: 步骤 4 中的图像 1,1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Volume Button Replacement: 步骤 5 中的图像 1,1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Volume Button Replacement: 步骤 6 中的图像 1,1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Volume Button Replacement: 步骤 7 中的图像 1,1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Volume Button Replacement: 步骤 8 中的图像 1,1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Volume Button Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Note5 Volume Button Replacement: 步骤 9 中的图像 2,2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Volume Button Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note5 Volume Button Replacement: 步骤 10 中的图像 2,2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Volume Button Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note5 Volume Button Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Volume Button Replacement: 步骤 12 中的图像 1,1
    • Push out the power button with the tip of the tweezers.
  13. Samsung Galaxy Note5 Volume Button Replacement, Volume Button: 步骤 13 中的图像 1,2 Samsung Galaxy Note5 Volume Button Replacement, Volume Button: 步骤 13 中的图像 2,2
    • Loosen the volume flex adhesive.
    • Pry up and remove the volume button flex.
  14. Samsung Galaxy Note5 Volume Button Replacement: 步骤 14 中的图像 1,1
    • Push out the volume button and remove it from the device.
结论
3等其他人完成本指南。
Bernice Nunez
于04/19/18注册
361 声望
创作了2篇指南
团队
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G17
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,430
