跳转到主内容
Samsung Galaxy Note5 Display Replacement
你所需要的
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: 步骤 1 中的图像 1,1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: 步骤 2 中的图像 1,1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: 步骤 3 中的图像 1,1
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: 步骤 4 中的图像 1,1
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Display Replacement: 步骤 5 中的图像 1,1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: 步骤 6 中的图像 1,1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: 步骤 7 中的图像 1,1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: 步骤 8 中的图像 1,1
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Note5 Display Replacement: 步骤 9 中的图像 2,2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Display Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Note5 Display Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Note5 Display Replacement: 步骤 10 中的图像 3,3
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: 步骤 11 中的图像 1,1
    • Loosen the two signal cable connectors.
  12. Samsung Galaxy Note5 Display Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Note5 Display Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Note5 Display Replacement: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
  13. Samsung Galaxy Note5 Display Replacement: 步骤 13 中的图像 1,1
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: 步骤 14 中的图像 1,1
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: 步骤 15 中的图像 1,3 Samsung Galaxy Note5 Display Replacement: 步骤 15 中的图像 2,3 Samsung Galaxy Note5 Display Replacement: 步骤 15 中的图像 3,3
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
  16. Samsung Galaxy Note5 Display Replacement: 步骤 16 中的图像 1,1
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: 步骤 17 中的图像 1,1
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: 步骤 18 中的图像 1,1
    • The display is now removed.
结论
41等其他人完成本指南。
Alexander Laucius
于04/19/18注册
1,659 声望
创作了2篇指南
团队
Cal Poly, Team S25-G17, Maness Spring 2018 Cal Poly, Team S25-G17, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G17
4 名成员
创作了6篇指南
6指南评论
Worked like a charm
Ronald Sapp - 回复
How does one bond everything back together?
lcplthomasc - 回复
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 90
总计 26,220
