简介
Use this guide to remove or replace the battery on your Samsung Galaxy Note10+. If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
你所需要的
Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the display cable connector from the motherboard.
Apply a few drops of high concentration (90% or greater) isopropyl alcohol underneath the battery at the tear-shaped indents near the corners of the battery well.
Wait about two minutes for the isopropyl alcohol to penetrate and weaken the battery adhesive before you proceed to the next step.
Apply a suction cup to the back of the battery.
Pull up on the suction cup with strong, steady force to begin to separate the battery from the frame.
Insert the point of an opening pick into the gap created between the battery and frame.
Pull up on the suction cup to remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
10等其他人完成本指南。
3条评论
What kind of adhesive would you recommend to adhere the back glass to the phone after repair?
Hey! Here’s a link to the rear cover adhesive!
Thank you! I have all my stuff ordered now. I can’t wait to follow this guide and get my battery back to new!
