跳转到主内容
Samsung Galaxy Note Speaker Enclosure Replacement
你所需要的
  1. Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: 步骤 1 中的图像 2,2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: 步骤 2 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 3 中的图像 2,2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Speaker Enclosure Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement, Battery: 步骤 4 中的图像 2,2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: 步骤 5 中的图像 1,3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: 步骤 5 中的图像 2,3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: 步骤 5 中的图像 3,3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 6 中的图像 1,1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: 步骤 7 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: 步骤 7 中的图像 2,2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 8 中的图像 2,2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Speaker Enclosure Replacement, Midframe: 步骤 9 中的图像 1,1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 10 中的图像 2,2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 11 中的图像 3,3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 12 中的图像 3,3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 13 中的图像 2,2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Speaker Enclosure Replacement, Speaker Enclosure: 步骤 14 中的图像 1,1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  15. Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy Note Speaker Enclosure Replacement: 步骤 15 中的图像 2,2
    • Remove the speaker enclosure from the display assembly.
结论
6等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,602 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,172
