跳转到主内容
Samsung Galaxy Note Pro 12.2 SD Port Replacement
你所需要的
  1. Samsung Galaxy Note Pro 12.2 SD Port Replacement, SD Port: 步骤 1 中的图像 1,1
    • Turn off your device before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 2 中的图像 2,2
    • Pop up the orange tab connected to the SD port with the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 3 中的图像 2,2
    • Remove the one 3mm Phillips #00 screw connected to the SD port.
  4. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 4 中的图像 2,2
    • Pop open the orange wire tab connected to the SD port with the plastic opening tool.
    • If there is tape covering your tab, remove it with the tweezers before you pop open the tab.
  5. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 5 中的图像 2,2
    • Using the orange tab, pull the SD port up and away from the device.
  6. Samsung Galaxy Note Pro 12.2 SD Port Replacement: 步骤 6 中的图像 1,1
    • Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
    • There is a little indent below the orange tab to help get under this piece. It may be difficult to remove, push up hard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 494
