跳转到主内容
Samsung Galaxy Note Pro 12.2 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Note Pro 12.2 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the back cover with the blue plastic opening tool.
  2. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Disconnect the five base connectors from the motherboard by using the blue opening tool to carefully remove the connectors.
  3. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the yellow tape on the ribbon cables before attempting to disconnect them from the motherboard.
    • Using the blue opening tool, pry on the black tab at the base connector of ribbon cables until it is flipped up and moves with ease. Then, pull the ribbon cable from the base connectors of the motherboard.
  4. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Potential damage to the motherboard could occur without supporting the black motherboard connector as the white cable connector is being removed.
    • Remove the power cable from the motherboard by prying slightly on both sides of the clip using tweezers.
  5. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove all three of the 3.0 mm screws using the Phillips #00 screwdriver.
    • It is easiest to pry on the points depicted in the pictures for the next step.
    • Use the blue plastic opening tool to pry the speakers up from the clips that hold them in place.
  6. Samsung Galaxy Note Pro 12.2 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard using the blue opening tool while keeping any wires and connectors out of the way.
    • The motherboard should come out freely.
结论
2等其他人完成本指南。
La'Taja Long
于11/04/19注册
346 声望
创作了3篇指南
团队
IUPUI, Team S1-G3, Henning Fall 2019 IUPUI, Team S1-G3, Henning Fall 2019 的会员
IUPUI-HENNING-F19S1G3
3 名成员
创作了3篇指南
一条评论
Hi. Can i install sm-p905 motherboard into my sm-p900?
yem44 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,086
