跳转到主内容
Samsung Galaxy Note Pro 12.2 Audio Jack Replacement
你所需要的
  1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement, Audio Jack: 步骤 1 中的图像 1,1
    • Make sure that your device is powered off before starting your repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 2 中的图像 2,2
    • Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
  3. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
  4. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 4 中的图像 2,2
    • Remove the two 3mm Phillips #00 screws over the silver cover.
    • The silver cover is attached to the whole audio jack; do not try to pull this away by itself.
  5. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 5 中的图像 2,2
    • Pop up the green connecter by gently pulling up.
  6. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 6 中的图像 2,2
    • Pull up on the circular amp with the spudger tool to release it from the device.
  7. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: 步骤 7 中的图像 1,1
    • Remove the whole audio jack by pulling gently up on the copper piece.
    • This component is extremely fragile.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 667
