跳转到主内容
简介
Prerequisite for removing the motherboard.
配件
没有特定配件。
  1. Use the flat end of a spudger to carefully disconnect the display cable connector. Use the flat end of a spudger to carefully disconnect the display cable connector.
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  2. Use a spudger to disconnect the front-facing camera assembly cable connector. Disconnect the headphone jack/earpiece speaker assembly cable connector. Disconnect the digitizer cable connector.
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  3. Disconnect the soft button cable connector with the flat end of a spudger. Use a spudger to disconnect the USB board cable connector. Disconnect the antenna cable connector.
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  4. Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  5. Remove the motherboard assembly from the display assembly. Remove the motherboard assembly from the display assembly.
    • Remove the motherboard assembly from the display assembly.
结论
Sam Goldheart
于2012年10月18日注册
439,527 信誉积分
创作了547篇指南
团队
iFixit iFixit 的会员
Community
138 名成员
创作了16,439篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 87
