简介
Refer to the device's troubleshooting page before replacing the micro USB port. If your Micro USB connection is not working properly, check the cord before replacing the port. Other reason's to replace the Micro USB include phone does not charge with a new charger or the Micro USB port malfunctions.
你所需要的
Make sure the screen is face-down and the camera is opposite you.
Insert the flat end of a spudger into the phone's top right rectangular slot.
Use the spudger as a lever to pry open the back of the phone.
Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
Turn the phone so the screen is on the table and the USB port is facing you.
Disconnect the orange ribbon near the bottom of the device using a spudger.
20等其他人完成本指南。
