跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note II USB Board Replacement
你所需要的
    1. Samsung Galaxy Note II USB Board Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement, Stylus: 步骤 1 中的图像 2,2
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II USB Board Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement, Rear Case: 步骤 2 中的图像 2,2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II USB Board Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note II USB Board Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note II USB Board Replacement: 步骤 3 中的图像 3,3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II USB Board Replacement, MicroSD Card: 步骤 4 中的图像 1,3 Samsung Galaxy Note II USB Board Replacement, MicroSD Card: 步骤 4 中的图像 2,3 Samsung Galaxy Note II USB Board Replacement, MicroSD Card: 步骤 4 中的图像 3,3
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II USB Board Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement, Battery: 步骤 5 中的图像 2,2
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II USB Board Replacement: 步骤 6 中的图像 1,1
      • Remove the battery from the midframe.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II USB Board Replacement, Midframe: 步骤 7 中的图像 1,1
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      添加评论
    2. Samsung Galaxy Note II USB Board Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Note II USB Board Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Note II USB Board Replacement: 步骤 8 中的图像 3,3
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      添加评论
    3. Samsung Galaxy Note II USB Board Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Note II USB Board Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Note II USB Board Replacement: 步骤 9 中的图像 3,3
      • Continue to run the plastic opening tool down the seam.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note II USB Board Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement: 步骤 10 中的图像 2,2
      • Carefully pry around the corner with a plastic opening tool.
      添加评论
    5. Samsung Galaxy Note II USB Board Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement: 步骤 11 中的图像 2,2
      • Pry along the top of the phone with a plastic opening tool.
      询问修复机器人
      添加评论
    6. Samsung Galaxy Note II USB Board Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement: 步骤 12 中的图像 2,2
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      询问修复机器人
      添加评论
    7. Samsung Galaxy Note II USB Board Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement: 步骤 13 中的图像 2,2
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      添加评论
    8. Samsung Galaxy Note II USB Board Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement: 步骤 14 中的图像 2,2
      • Lift the display assembly out of the midframe.
      添加评论
    1. Samsung Galaxy Note II USB Board Replacement, Speaker Enclosure: 步骤 15 中的图像 1,1
      • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II USB Board Replacement: 步骤 16 中的图像 1,1
      • Remove the speaker enclosure.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II USB Board Replacement, USB Board: 步骤 17 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement, USB Board: 步骤 17 中的图像 2,2
      • Using the flat end of a spudger, disconnect the USB board cable connector.
      • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II USB Board Replacement: 步骤 18 中的图像 1,2 Samsung Galaxy Note II USB Board Replacement: 步骤 18 中的图像 2,2
      • Push the flat end of a spudger under the USB board to separate it from the display assembly.
      • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Note II USB Board Replacement: 步骤 19 中的图像 1,1
      • Remove the USB board from the display assembly.
      添加评论
结论
取消:我没有完成这个指南。
68等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,905 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了61,359篇指南
10指南评论
Super easy thank you
jalamson - 回复 分享
класс, только добавьте пожалуйста русский язык
abdul8477 - 回复 分享
Very good tutorial of the process needed to do this repair. Sadly the one that I was trying to repair had been dropped and the circuit board right where the charge pcb attaches was physically cracked. Did not find that problem until actually removing the original part and throughly inspecting the connect area. Thank You again for an excellent tutorial and dialogue.
stubbie45 - 回复 分享
Excellent tutorial regarding the disassembly of the Note II and replacement if the charge circuit board. Sadly the device i have had been dropped and the main circuit board where the charge PCB plugs into it was fractured. After removal of the original charge board through inspection noted the original problem was the cracked main PCB. :( Now I have a Note II with a good case and display but damaged main circuit board.
stubbie45 - 回复 分享
I replaced my USB board and success. However my speakers are not working now. Someone please guide me .
Elijah Williamson - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 51
总计 39,561
