跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note II Rear Facing Camera Assembly Replacement
你所需要的
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Stylus: 步骤 1 中的图像 2,2
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Case: 步骤 2 中的图像 2,2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 3 中的图像 3,3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 步骤 4 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 步骤 4 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, MicroSD Card: 步骤 4 中的图像 3,3
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Battery: 步骤 5 中的图像 2,2
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 6 中的图像 1,1
      • Remove the battery from the midframe.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Midframe: 步骤 7 中的图像 1,1
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      添加评论
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 8 中的图像 3,3
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      添加评论
    3. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 9 中的图像 3,3
      • Continue to run the plastic opening tool down the seam.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 10 中的图像 2,2
      • Carefully pry around the corner with a plastic opening tool.
      添加评论
    5. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 11 中的图像 2,2
      • Pry along the top of the phone with a plastic opening tool.
      询问修复机器人
      添加评论
    6. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 12 中的图像 2,2
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      询问修复机器人
      添加评论
    7. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 13 中的图像 2,2
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      添加评论
    8. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 14 中的图像 2,2
      • Lift the display assembly out of the midframe.
      添加评论
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 3,3
      • Use a spudger to disconnect the vibrator/power button assembly cable connector.
      • Disconnect the antenna cable connector.
      • Disconnect the display cable connector.
      添加评论
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 16 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 16 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 16 中的图像 3,3
      • Disconnect the front-facing camera cable connector.
      • Disconnect the headphone jack cable connector.
      • Disconnect the digitizer cable connector.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 17 中的图像 1,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 17 中的图像 2,3 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 17 中的图像 3,3
      • Use the spudger to disconnect the antenna cable connector from the motherboard.
      • Disconnect the soft button cable connector.
      • Disconnect the USB board cable connector.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 18 中的图像 1,1
      • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
      添加评论
    5. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 19 中的图像 1,2 Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 19 中的图像 2,2
      • Gently remove the motherboard.
      • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement, Rear Facing Camera Assembly: 步骤 20 中的图像 1,1
      • Use a spudger to disconnect the rear-facing camera assembly cable connector.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II Rear Facing Camera Assembly Replacement: 步骤 21 中的图像 1,1
      在这个步骤中使用的工具:
      • Use tweezers, or your fingers, to remove the rear-facing camera assembly.
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,905 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了61,353篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 53
总计 12,737
