本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a Galaxy Note II midframe.
你所需要的
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
51等其他人完成本指南。
5条评论
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
How do I fix the glass
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
very very very useful brother
Brilliant Thanks.
