跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note II Midframe Replacement
你所需要的
  1. Samsung Galaxy Note II Midframe Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement, Stylus: 步骤 1 中的图像 2,2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Midframe Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement, Rear Case: 步骤 2 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Midframe Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note II Midframe Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note II Midframe Replacement: 步骤 3 中的图像 3,3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 步骤 4 中的图像 1,3 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 步骤 4 中的图像 2,3 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: 步骤 4 中的图像 3,3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Midframe Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Midframe Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Midframe Replacement, Midframe: 步骤 7 中的图像 1,1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Midframe Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Note II Midframe Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Note II Midframe Replacement: 步骤 8 中的图像 3,3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Midframe Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Note II Midframe Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Note II Midframe Replacement: 步骤 9 中的图像 3,3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Midframe Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement: 步骤 10 中的图像 2,2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Midframe Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement: 步骤 11 中的图像 2,2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Midframe Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement: 步骤 12 中的图像 2,2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Midframe Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement: 步骤 13 中的图像 2,2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Midframe Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Note II Midframe Replacement: 步骤 14 中的图像 2,2
    • Lift the display assembly out of the midframe.
结论
52等其他人完成本指南。
Sam Goldheart
于10/18/12注册
475,809 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,048篇指南
5指南评论
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
milankerslager - 回复
How do I fix the glass
Nena Summer Perez - 回复
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
HARDIK PANCHOLI - 回复
very very very useful brother
Arunkrishna T H - 回复
Brilliant Thanks.
michaeleggar6 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 113
总计 30,998
