跳转到主内容
Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement
你所需要的
  1. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Stylus: 步骤 1 中的图像 2,2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Rear Case: 步骤 2 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 3 中的图像 3,3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: 步骤 4 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: 步骤 4 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: 步骤 4 中的图像 3,3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Midframe: 步骤 7 中的图像 1,1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 3,3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 9 中的图像 3,3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 10 中的图像 2,2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 2,2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 2,2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 13 中的图像 2,2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 14 中的图像 2,2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 3,3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
  16. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 16 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 16 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 16 中的图像 3,3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  17. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 17 中的图像 1,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 17 中的图像 2,3 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 17 中的图像 3,3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  18. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 18 中的图像 1,1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
  19. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 19 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 19 中的图像 2,2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  20. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement, Headphone Jack/Earpiece Speaker Assembly: 步骤 20 中的图像 1,1
    • Remove the 3 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
  21. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 21 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 21 中的图像 2,2
    • Grasp the headphone jack portion of the assembly and lift it out of its groove in the display assembly.
  22. Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 22 中的图像 1,2 Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 22 中的图像 2,2
    • Gently pull the headphone jack straight up without twisting the cable to remove the earpiece speaker portion from its recess.
    • Twisting or pulling unevenly could damage the cable. Be very careful as you extract the assembly.
结论
42等其他人完成本指南。
Sam Goldheart
于10/18/12注册
474,941 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,612篇指南
5指南评论
Thanks for the help. I have fixit the my Headphone Jack/Earpiece Speaker easily with these tutorial. The only difficult was the reassemble the antenna cable connector.
Giorgio
Giorgio - 回复
Sooo, to replace the earpiece assembly, you have to bust your screen?
David - 回复
Did you use the miniature hammer for that step David?
Jasen Putney -
Where can I purchase a headphone jack to replace my defective one?
jimhyunglee - 回复
Installed everything correctly. Ear piece works fine, however my headphone jack (which was the faulty component in the first place) does not work at all. The phone does not even detect when I have a pair of earbuds plugged in. I replaced this piece due to heavy static out of the headphone jack.
Chris Del Sesto - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 66
过去 30 天: 173
总计 58,053
