跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note II Front Facing Camera Assembly Replacement
你所需要的
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: 步骤 1 中的图像 2,2
      • Grasp the end of the stylus and remove it from its slot in the midframe.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: 步骤 2 中的图像 2,2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 3 中的图像 3,3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: 步骤 4 中的图像 1,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: 步骤 4 中的图像 2,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: 步骤 4 中的图像 3,3
      • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: 步骤 5 中的图像 2,2
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 6 中的图像 1,1
      • Remove the battery from the midframe.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Midframe: 步骤 7 中的图像 1,1
      • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      添加评论
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 8 中的图像 3,3
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seam.
      添加评论
    3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 9 中的图像 3,3
      • Continue to run the plastic opening tool down the seam.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 10 中的图像 2,2
      • Carefully pry around the corner with a plastic opening tool.
      添加评论
    5. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 11 中的图像 2,2
      • Pry along the top of the phone with a plastic opening tool.
      询问修复机器人
      添加评论
    6. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 12 中的图像 2,2
      • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
      询问修复机器人
      添加评论
    7. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 13 中的图像 2,2
      • Free the clips along the power button side of the phone.
      • Lastly, free the two clips along the top and bottom edge of battery compartment.
      添加评论
    8. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 14 中的图像 2,2
      • Lift the display assembly out of the midframe.
      添加评论
    1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: 步骤 15 中的图像 1,1
      • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 16 中的图像 1,1
      • Remove the front-facing camera bracket.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 17 中的图像 1,1
      • Use the flat end of a spudger to disconnect the front-facing camera connector.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: 步骤 18 中的图像 1,1
      • Remove the front-facing camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,905 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了61,352篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 47
总计 12,405
